Air Carbon Arc Gouging: What is it and How Does it Work?
August 25, 2021
Understanding Air Carbon Arc Gouging: Technique, Advantages, & Application
Air carbon arc gouging process is simple, easy, and economical. In this article, we will walk through the process of air carbon arc gouging, how the technique works, and review the application and advantages.
What Is Air Carbon Arc Gouging?
Air carbon arc gouging is a thermal cutting process of removing or severing metal by heat from a carbon arc. The process uses a carbon/graphite electrode, a standard power source, and compressed air. The intense heat arc produced between the tip of the electrode and the metal workpiece melts and cuts the metal. The air carbon arc gouging technique is used to remove any old or defective welds for repairing or dismantling equipment.
How Does Air Carbon Arc Gouging Technique Work?
Required Equipment
  • Carbon/graphite electrode
  • Gouging torch
  • Standard power source
  • Compressed air
A copper-coated carbon electrode or graphite electrode is used to generate an arc. The copper coating minimizes electrode erosion. Here, the electrode diameter plays a crucial role in reducing waste. Select the right diameter based on the width and depth of the gouge. Using the correct electrode diameter helps to precisely control cutting or gouging and reduce material waste.
Gouging torch
The power source needs to be of high voltage capacity. DC (direct current) is suitable for steel and stainless steel whereas AC (alternating current) is suitable for copper, iron, and nickel alloys. It is critical for the power source to have a constant current output to prevent the high voltage current from causing the electrode tip to explode when brought in contact with the metal workpiece.
Compressed air
Areas of Application
Air carbon arc gouging does not depend on oxidation, making the process suitable for various metals. Typical applications include back gouging, removal of excess weld metal, removal of internal or surface defects, and preparation of bevel edges for welding.
  • Construction
  • General repair
  • Maintenance purpose
  • Mining
  • Metal fabrication and casting finishing
  • Chemical and petroleum technology
Advantages Of Air Carbon Arc Gouging
  • The process can gouge almost all common metals
  • The process is five times faster than chipping
  • The temperature of the area around the cut metals does not reach the maximum as the molten metal is quickly removed by air jet after melting
Air carbon arc gouging is the process of removing metal from the workpiece using the heat of a carbon arc, compressed air, and power source. Simple, fast, and easy, the process can efficiently gouge almost all metals making it suitable for various industrial applications.
ESAB is a world leader in the production of welding and cutting equipment, consumables, and automation equipment. We can answer questions you have about welding and cutting. Our gouging equipment is designed with advanced technology to help accomplish your projects.
