Unfortunately, many shops still take a manual approach to this process of traceability. The problem is that it’s time-consuming, costly, and leaves room for typos and errors.
In addition, a highly paid engineer is typically the one entering in the information, meaning their valuable time is eaten away by paperwork. In fact, it can take days for them to enter all the variables related to a specific project.
